Quake II questions on O2
chemdream
Unread postby chemdream » Tue Oct 04, 2016 2:54 pm
Hi! I just finally got Quake 2 (with demos, no piracy) working on my O2.
Few questions I'm hoping you guys can help with.
-Any idea how I get it to capture the mouse totally? My mouse keeps moving off the window and then not doing anything to Quake...
-I have a 1600SW w/external VGA adapter. What is the highest resolution I can get Quake II? At it's highest, even in "Full screen mode" it's still just a little window.
THANK YOU!!!!!!!!!!!!!!
Re: Quake II questions on O2
Unread postby vishnu » Tue Oct 04, 2016 5:37 pm
chemdream wrote:Hi! I just finally got Quake 2 (with demos, no piracy) working on my O2.
That's a window manager issue, you want to put Mwm*keyboardFocusPolicy: pointer into your ~/.Xdefaults
chemdream wrote:-I have a 1600SW w/external VGA adapter. What is the highest resolution I can get Quake II? At it's highest, even in "Full screen mode" it's still just a little window.
The sizeup command. A complete list of all Quake II console commands:
https://www.eecis.udel.edu/~portnoi/quake/quakeiicom.html
chemdream
Unread postby chemdream » Wed Oct 05, 2016 5:31 am
Thank you!
chemdream
Unread postby chemdream » Thu Oct 06, 2016 2:00 pm
Actually, that .xDefaults update didn't seem to do anything? Any other ideas?
Thanks!!
Unread postby vishnu » Thu Oct 06, 2016 3:59 pm
Hrmph! My bad, try 4Dwm*keyboardFocusPolicy: explicit then. To get your edit to .Xdefaults to take immediate effect (as opposed to having to restart the window manager or log out and back in again): xrdb -merge ~/.Xdefaults
duck
Unread postby duck » Fri Oct 07, 2016 12:23 pm
You don't need to change any X resources, just put set _windowed_mouse "1" into your baseq2/config.cfg and it'll automatically grab your mouse pointer.
___(o)=
\____)
