Did my Fuel gfx go tits up?
s0ke
Unread postby s0ke » Sun Feb 21, 2016 12:02 pm
So my Fuel has been chugging along nicely for that last few years. Minus the machine not keeping the date when its unplugged. A minor issue and I have been meaning to replace the dallas chip to fix that. However today I have no graphics on the machine. It boots up fine and I can ssh into, but zero shows up on the screen. I connected a serial cable to see the output:
Running in DDR mode
*** Skipping diags as requested by kernel
*** Diag level set to None (2)
Discovering local IO ......................             DONE
Local hub NUMAlink is down.
*** Local network link down
DONE
Found 1 objects (1 hubs, 0 routers) in 30358 usec
Intializing any CPUless nodes..............             DONE
BASEIO PROM Monitor SGI Version 6.210  built 02:30:38 PM Aug 26, 2004 (BE64)
1 CPUs on 1 nodes found.
Walking SCSI Adapter 0, (pci id 1)
1+ Device Vendor Product: FUJITSU MAM3367MC
2- 3- 4- 5- 6- 7- 8- 9- 10- 11- 12- 13- 14- 15- = 1 device(s)
Walking SCSI Adapter 1, (pci id 1)
1- 2- 3- 4- 5- 6+ Device Vendor Product: TOSHIBA DVD-ROM SD-M1711
odsy: frame buffer/fullscreen accum config causes oversubscription of sdram.
I came across another reference to this in forum post: viewtopic.php?t=16725016. Down at the very bottom there was a link to another page that looked like a vpro replacement was needed.
Is there anything else I can look at? Or has my gfx board been done in.
Thanks
:Fuel: REFUSE
R16K 700: 2GB: V10: Noctua Fans
Re: Did my Fuel gfx go tits up?
Unread postby jan-jaap » Sun Feb 21, 2016 12:26 pm
s0ke wrote:
Sounds like a garbled configuration rather than a hardware problem. Did you try to reset the PROM variables and/or reset the graphics configuration, e.g. /usr/gfx/setmon 1280x1024_60
s0ke
Unread postby s0ke » Sun Feb 21, 2016 12:46 pm
Yes sir. Still just a black screen. I don't even get the boot splash screen anymore.
Found this in the SYSLOG:
WARNING: odsy board 0: dma: o2p:2 csv:0x2
Not 100% what that means.
The plot thickens:
Graphics diagnostics
        Board version 1 - Buzz revision 2B
        On board sdram size: 32 Mb
        Cas latency: CAS 3
        4 banks by sdram module
Device passed diagnostics
enet_ssram failed: Failed address walk test
RSLT enet_ssram     FAIL                diag_rc = 102 Failed address walk test
enet_ssram: ssram address walk error. Exp: 00000 Recv: 01010
enet_ssram: ssram address walk error. Exp: 00101 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00202 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00303 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00404 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00505 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00606 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00707 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00808 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00909 Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00a0a Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00b0b Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00c0c Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00d0d Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00e0e Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 00f0f Recv: 2ffff
enet_ssram: ssram address walk error. Exp: 01010 Recv: 2ffff
enet_ssram: IOC3 ssram test failed ....
enet_all: SSRAM test failed.
:Fuel: REFUSE
Unread postby jan-jaap » Sun Feb 21, 2016 2:35 pm
s0ke wrote:Yes sir. Still just a black screen. I don't even get the boot splash screen anymore.
A 'resetenv' has reset the console to the serial port. A 'setenv console g' will fix that.
s0ke wrote:Found this in the SYSLOG:
Me neither.
s0ke wrote:
This, on the other hand, is more serious. 'enet_ssram' is associated with the ethernet port. I had to toss an IO6G for an Onyx2 once which developed this problem. Of course in this case it's on the mainboard, but if the ethernet port is really cooked you can always install a gigabit ethernet card in a PCI slot. I even think I still have one of those ;)
s0ke
Unread postby s0ke » Sun Feb 21, 2016 3:21 pm
Thank you. I will attempt to reset it if I can get it back in working order again. Things seem to be gradually getting worse by the minute:
SGI SN1 L1 Controller
Firmware Image B: Rev. 1.22.6, Built 08/07/2003 12:56:31
001a01-L1>
001a01-L1>
entering console mode  001a01 console, <CTRL_T> to escape to L1
Starting PROM Boot process
no response from  001a01 CPU0, system not responding
I'm going to re-seat everything and hope for the best.
So apparently my prom was fragged. After following this excellent post: viewtopic.php?f=3&t=16727613&p=7359114&#p7359114. The system boots back up, but alas the gfx still doesn't work.
I ran the following:
setenv console g
And I also set the gfx back to 1280x1024_60. And HUP X. Still black. Even tried a different monitor and nada. So while I'm bummed the gfx doesn't seem to work anymore, at least its not the entire board.
:Fuel: REFUSE
Unread postby Trippynet » Mon Feb 22, 2016 2:54 am
Reseating everything can be a good idea. My Fuel became increasingly flaky last year (at around the same time as the batteries were dying). Eventually, it started completely freaking out, failing to boot at times, randomly turning on and off, crashing whilst in use - often with weird graphical corruption, sometimes booting but not giving a display, etc.
After replacing both batteries, the sporadic behaviour continued. I then pulled it completely apart and reseated everything apart from the CPU. After putting it back together, it promptly fired up fine, and it's been running 100% rock solid for the last few months without a hiccup.
Of course, YMMV...
s0ke
Unread postby s0ke » Mon Feb 22, 2016 8:52 am
I will have to re-seat the vpro when I'm back home. I put my old fans back in as well after having swapped them for the Noctuas. Thinking that may have been the cause but didn't seem to matter at all.
:Fuel: REFUSE
Unread postby Trippynet » Mon Feb 22, 2016 1:49 pm
It's possible that whilst installing them something may have been knocked/disturbed. Fuels can be finicky like this unfortunately. Hope you get it sorted and end up with a quiet and working Fuel! If you do replace the batteries, it's not too much of a faf - but do note the comments from others on here about it. I fully agree with jan-jaap's finding that a removal tool makes it a LOT easier to change them!
Unread postby recondas » Mon Feb 22, 2016 3:56 pm
s0ke wrote:.....the machine not keeping the date when its unplugged.
Along with the other fixes suggested, I'd suggest putting replacing of the timekeeper on the top end of the to do list. The Fuel originally used an a ST M4T28-BR12SH1 Lithium timekeeper battery, but several here have successfully used the compatible/higher capacity ST M4T32. Details are available in this thread: viewtopic.php?f=3&t=16728064&p=7363678&#p7363678
s0ke
Unread postby s0ke » Tue Feb 23, 2016 7:21 am
Yes I have been meaning to fix it. It's generally not much of an issue as I usually leave the machine plugged in, but it recently made a move from the closet to under my desk.
:Fuel: REFUSE
s0ke
Unread postby s0ke » Fri Apr 15, 2016 9:54 am
TOD chip replaced. So far system works fine (and keeps the date now :) ) but gfx still won't work. Only thing I see during boot:
I have a gigabit ethernet card so I'm not as worried about that.
I guess I'm gonna have to bite the bullet and get another v10 or maybe the ebay gods will take pity on me and put a v12 in my path.
But is there any other troubleshooting I could do aside from swapping different parts? It just seems strange to me that the gfx pass the diags (not that the diags are worth much) and the system sees the card.
:Fuel: REFUSE
mopar5150
Unread postby mopar5150 » Fri Apr 15, 2016 10:28 am
PM me your address and I will send you a V10 for the cost of shipping. $12
:Tezro: :O3x0: :A350:
opcode
Unread postby opcode » Wed Aug 10, 2016 8:24 am
I came for the tits but stayed for the fix! Now I need to know what happened! :)
:PrismDT: :Tezro: :Onyx2: :Indigo: :Indigo: :Indigo: :Indigo: :Indigo: :Indigo: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy: :O2: :O2: :O2: :O2: :O2: :1600SW: :1600SW: :320: :Indigo2IMP: :Indigo2: :Octane2: :Octane2: :Octane: :Fuel: :Fuel:
Stolen! :4D310: :Crimson:
s0ke
Unread postby s0ke » Mon Oct 03, 2016 11:53 am
Honestly I'm not sure but the new v10 fixed it right up.
:Fuel: REFUSE
s0ke
Unread postby s0ke » Wed Oct 05, 2016 3:09 pm
Well hell. Now the front disk fan and gfx card fans stopped working. Is it possible for those pins to just die on the board?
Edit:
Thank god my Noctuas had some extra molex connectors bypassed the jumper on the board and connected directly to power :) all is well.
:Fuel: REFUSE
