SGI Indy R5000 workstation in the house ..
seclorum
Unread postby seclorum » Fri Jan 01, 2016 1:12 pm
Hi SGI fans,
So I was a heavy SGI user back in the day, had myself a personal Indy stack in my lab for development (software), had some great connections in the Hollywood SGI scene for software and so on, and had a great time until SGI moved to NT and I decided to move to Apple for my hardware needs - perhaps there are others in this boat.
I was recently given an SGI Indy for free! This was a great gift, and my task now is to get it up and running and fully functioning as a workstation - it came with no cables, but the previous owner said "it makes the boot sound when you plug it in" .. so there is hope.
What I'd like to know is if anyone has any tips or tricks for me about what to do with these old machines these days. Ultimately I'd love to fill it to the brim with working software - there was a game whose name I cannot remember, but it was awesome - it was like a ringworld-in-space kind of mech shooter .. think this will run on this Indy? It has as far as I can tell, 128megs of RAM, an R5000 (badge), and the stock SCSI internal disks .. but I haven't boosted it yet, since I don't have a monitor/keyboard/mouse combination for it yet ..
I'm thinking of doing the Internal VGA modification documented on the wiki - anyone else done this, if so, tips/hints?
I also have an O2 machine available - if I can get both of these machines in working order, I'll be tickled SGI blue .. anyone got any clues what to do with these two machines if I get them up and running? Would love to have some sort of functionality - even if its rudimentary - out of them as workstations ...
EDIT: Wanted to add pics, in case its of interest ..
Krokodil
Re: SGI Indy R5000 workstation in the house ..
Unread postby Krokodil » Fri Jan 01, 2016 3:21 pm
seclorum wrote:Hi SGI fans,
Welcome. The game you mentioned may be called Mekton. I don't know much else about Indy's since I've never had access to one.
Unread postby dexter1 » Sat Jan 02, 2016 5:05 am
Welcome Seclorum to the hideout of SGI enthusiasts :)
Congratulations on your free Indy! By the looks of it, it has an R5K 150 or 180 MHz processor with secondary cache. About as fast as it can get on this workstation. Indy memory maxes out at 256 MByte. The old disks are probably noisy, so i recommend them to exchange with newer disks. It's not for the higher throughput, since that is limited at 10 Mbyte/sec because of the SCSI bus.
Your graphics is 8 bit XL which is the entry spec.
The indy has cool stuff for its time. A Indycam is very welcome, even if its image quality is low for today's standard. It has analog video input and decent 4 channel audio capabilities.
Try to get some IRIX OS media like irix 6.2 or 6.5. the last IRIX supporting the indy is 6.5.22m.
Browse around and look at what people made for these machines. We still develop applications or port stuff from the Linux world onto our IRIX boxes. You will love the O2's too btw.
Unread postby ClassicHasClass » Mon Jan 04, 2016 7:21 am
An R5000 Indy for free? Nice!
The Indy is my favourite SGI.
seclorum
Unread postby seclorum » Sun Jan 24, 2016 3:04 am
ivelegacy: the VGA modification is documented in the wiki here: http://www.nekochan.net/wiki/Indy_VGA_Hack
I haven't done it yet, but I will soon. Also, I'd kind of like to upgrade the graphics to 24-bit .. if anyone has an upgrade for sale, let me know.
seclorum
Unread postby seclorum » Sun Jan 24, 2016 3:05 am
Krokodil: Yup, thats the one - Mekton - thanks for the reminder! I hope I can get it working one of these days ..
Unread postby vishnu » Sun Jan 24, 2016 12:12 pm
pentium
Unread postby pentium » Thu Feb 25, 2016 8:05 pm
seclorum wrote:ivelegacy: the VGA modification is documented in the wiki here: http://www.nekochan.net/wiki/Indy_VGA_Hack
How did I never see that page? That shown pinout is incorrect (I must of been smoking something wild at the time to screw that up). The Indy is also one of the few SGI's that outputs a horizontal and vertical sync signal so you are not strictly limited to SoG monitors.
Using the 13W3 pinout listed on page 201 of the Indy Owners Guide....
      13W3                                         VGA
1 (Monitor Type 3) ------------------------- 15 (ID Bit 3)
2 (Monitor Type 0) ------------------------- 11 (ID Bit 0)
3 (Composite Sync) ------------------------- N/C
4 (Horiz. Sync) ---------------------------- 13 (Horiz. Sync)
5 (Vert. Sync) ----------------------------- 14 (Vert. Sync)
6 (Monitor Type 1) ------------------------- 12 (ID Bit 1)
7 (Monitor Type 2 -------------------------- 4 (ID Bit 2)
8 (Ground) --------------------------------- 6 (Red Shield)
9 (Ground)---------------------------------- 7 (Green Shield)
10 (Ground) -------------------------------- 8 (Blue Shield)
A1 (Red) ----------------------------------- 1 (Red)
A2 (Green) --------------------------------- 2 (Green)
A3 (Blue) ---------------------------------- 3 (Blue)
9 (Ground)* -------------------------------- 5 (Ground)
N/C ---------------------------------------- 9 (KEY/DDC +5v)
*All grounds are common, so it doesn't matter if you use pin 8, 9 or 10.
...hence why I soldered so many extra lines to the board. ;)
seclorum
Unread postby seclorum » Sat Feb 27, 2016 3:26 am
Okay, so .. I'm a bit confused. Should I follow the wiki info, or .. not .. if not .. why not? Coz it would probably be wise to update the wiki .. and I'm willing to test the changes if you can point out to me what is correct/incorrect.
Geoman
Unread postby Geoman » Sat Feb 27, 2016 3:40 am
Mekton is on "Silicon Graphics General & Platform Demos [1-of-2]"
Should be running great on that Indy (but is unforunately incompatible to VPro-based SGIs).
Unread postby dexter1 » Sat Feb 27, 2016 3:52 am
seclorum wrote:Okay, so .. I'm a bit confused. Should I follow the wiki info, or .. not .. if not .. why not? Coz it would probably be wise to update the wiki .. and I'm willing to test the changes if you can point out to me what is correct/incorrect.
Yesterday i changed the Wiki, so it now shows the correct pinout as Pentium suggested.
