DNS and Indy
marmotta
DNS and Indy
Unread postby marmotta » Wed Dec 23, 2015 9:07 am
I have a strange issue... I have fresh installed Irix 6.5 in my Indy, configured all... Dns not work! I able to ping only ip address's, not names!
This is the situation:
-The problem is with ping, netscape ecc...
-My resolv.conf is ok and the nameserver is the ip of the router (i have custom nameserver on it)
-My nsswitch.conf is "Hosts = files dns"
-NIS is off
-Gateway is ok and is the same address of the dns server
-I tried to use google nameserver (8.8.8.8) without success
If I insert a ip address of one of my servers is ok, if I insert names... no. :cry:
I have another Irix machine, one Octane with 6.5.30 and dns resolution work without problems...
What I missed on the way?
marmotta
Re: DNS and Indy
Unread postby marmotta » Wed Dec 23, 2015 5:30 pm
Solved!
resolv.conf want domain or search path! But the GUI configuration don't add it.... I have inserted the search path and now is all ok ;-)
