Hello again
DaJuice
Hello again
Unread postby DaJuice » Mon Nov 02, 2015 12:37 am
Hello nekochan, I just wanted to say hi to the great people here.
I'm not really new but it's been a long time since I've last posted. After my Trinitron display gave up the ghost (the only sync-on-green monitor I owned), I stashed the Octane in the closet where it sat neglected for the next few years. Recently my girlfriend and I moved into a new place, and this was the second time she had seen me lug the big green thing into a new closet. Naturally she asked wether I was going to hold onto it or maybe sell it/get rid of it. I can understand the question, it was kind of silly to just keep it sitting in the closet for so long. Well, I decided it was finally time to get her up and running again.
I hit up craigslist and found a decent-ish Dell LCD that supports SOG for $25.
The first thing I realized upon boot was that the white LED bulb in the lightbar had gone out. Other than that everything is okay. It's good to have an IRIX box again. :D
Yesterday I went ahead and did a little restoration on the skin, based on recommendations from a couple of threads here. I used Mr. Clean Magic Eraser and Mother's Back to Black.
Here is the front panel prior to the cleaning:
And here it is after scrubbing the paint/blemishes off with the magic eraser pad:
It works very well, but be aware (and this has been mentioned by others) that this can definitely take off some of the texture in the plastic and leave you with an un-even looking surface. Use as little pressure as you can to remove the paint/blemishes. Either way I would not recommend using these pads unless you are also going to apply some kind of wax as well.
Here are a couple of pics of the machine after applying Mother's Back to Black:
It's probably hard to tell in the photos, but it gives the color a noticeable bit of extra luster without making the surface too shiny. I like it a lot.
Other random thoughts/questions:
I would have thought Octane drive sleds would be more plentiful and easier to come by.
External SCSI CD ROM drives are a bit more expensive than I was expecting. What models do you folks use?
Are there any compact PS2 keyboards that work well with sgi boxes?
And finally... I think I have the bug again. The Octane will soon be joined by a Fuel.
Cheers all.
Re: Hello again
Unread postby recondas » Mon Nov 02, 2015 3:31 am
Welcome back, DaJuice. Nice work, your Octane looks great.
As far as external optical drives go, I personally like the Pioneer 303 or 304 SCSI DVD drives. Works as a boot/install drive and also supports IRIX's audio-over-scsi feature. There's also a decent sized list of known Octane-friendly CD/DVD drives over in the Octane Hardware Aggregator.
If you pick one with a key layout supported by IRIX, pretty much any PS/2 keyboard should work. The pckeyboard man page give the official rundown, but it's far from comprehensive:
Compatibility
     Most PC keyboards work out of the box (they may require a 5 pin DIN to 6
     pin mini-DIN) if they match the normal 101-key layout.  Keyboards with
     different or extra keys may require tuning of keyboard map.  The
     following keyboards have been tested (some only briefly) and seem to
     function correctly:
          SGI Indigo2 keyboards (US and several international models)
          SGI Indy keyboards (US and several international models)
          Kinesis ergonomic keyboard, Model 100, 110, 120 and 130
          Comfort Keyboard System
          IBM PS/2 Model M (P/N 1391401)
          IBM 101 Key Keyboard with Trackpoint II - PS Style (P/N 92G7461)
          Microsoft Natural Keyboard
          Compaq enhanced II keyboard, domestic/101
          Qtronix QX-601R
     Some keyboards that are known not to work, or require minor changes:
          Lexmark M13 (Select_ease) - Does not always power-on correctly.
                     See nogfxkbd option in prom(1m).
          Data Hand - Newer versions are reported to work, but older
               ones do not.
          PC Concepts Ergonomic - does not implement scan code set 3.
Re: Hello again
Unread postby dexter1 » Mon Nov 02, 2015 4:40 am
Hello DaJuice, good to see you back.
I've rejoined the community a month ago, and i hauled my old O2 back into my mancave so i'm with ya :)
There is the old LED mod for the Octane, which is a nice winter hobby project. CD Drives are tricky to find, but i have scavenged a few Toshiba SCSI models which i use to help some systems remove the root password. Maybe a yardsale somewhere will have these around.
Building a PC for IRIX network install will be my next task. I suggest you try it too, to not be too dependent on CD media.
Re: Hello again
Unread postby ClassicHasClass » Mon Nov 02, 2015 6:50 am
Nice restoration! Looking forward to you posting the formal hinv. :)
DaJuice
Re: Hello again
Unread postby DaJuice » Mon Nov 02, 2015 10:31 pm
Thank you guys for the warm welcome and the pointers. I will update the thread when the Fuel arrives (and post hinvs as well).
Krokodil
Re: Hello again
Unread postby Krokodil » Mon Nov 02, 2015 10:38 pm
Welcome, that's a very clean and nice Octane. I am afraid to polish mine for fear of messing it up lol.
But all in all they are very nice machines and I hope you love yours as much as I love mine.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
Re: Hello again
Unread postby vishnu » Tue Nov 03, 2015 4:24 pm
DaJuice wrote:I realized upon boot was that the white LED bulb in the lightbar had gone out.
All the bulbs on mine are out except the red one (which is the one that's only on up to successful POST or thereabout), why they felt they needed to use incandescent bulbs is a design fail that defies logical explanation... :x
DaJuice
Re: Hello again
Unread postby DaJuice » Tue Nov 03, 2015 8:03 pm
Krokodil wrote:Welcome, that's a very clean and nice Octane. I am afraid to polish mine for fear of messing it up lol.
Thanks Krokodil. In all honesty, I thought I had messed it up, but the MBTB evened everything out pretty well.
Yeah it's a mystery. This machine does actually have a LED modded lightbar, The LED just gave out for whatever reason.
Re: Hello again
Unread postby Trippynet » Wed Nov 04, 2015 12:24 am
DaJuice wrote:This machine does actually have a LED modded lightbar, The LED just gave out for whatever reason.
OK, that's even stranger. I'd guess either a wiring issue (snapped core or something), or whoever did it used the wrong resistor so that the LED burnt out.
Re: Hello again
Unread postby vishnu » Wed Nov 04, 2015 11:11 am
It's easy to check if the diode is nuked since most voltmeters have diode checkers these days. I've had it on my todo list to do the diode mod to my light bar for about eight years now... :mrgreen:
Krokodil
Re: Hello again
Unread postby Krokodil » Sun Nov 08, 2015 11:31 am
Interesting to see what I thought was wear on the O of the Octane is actually present on yours too.
DaJuice
Re: Hello again
Unread postby DaJuice » Sun Nov 08, 2015 5:17 pm
The diode in the Octane lightbar lit right up after poking and nudging it a bit. It's fine now. :oops:
The Fuel arrived! It's heavier than I was expecting for an ATX style chassis. The metal/plastics were not in bad shape but I gave them the machine the same treatment as the Octane. Please let me know if my photos are too large/excessive, I don't want to abuse the servers. Originally I was going to link to images on my photobucket, but photobucket is no good anymore.
Before & Afters:
Re: Hello again
Unread postby Trippynet » Mon Nov 09, 2015 12:18 am
Looks very nice, and an intact front door as well. You just need to pop up the hinv now!
Attaching the files is usually best incidentally as sites like Photobucket are always moving/changing around, and posts otherwise become outdated and incomplete if the photo host disappears. Whereas with attaching them here, they'll last as long as this forum lasts :)
Re: Hello again
Unread postby ClassicHasClass » Mon Nov 09, 2015 10:32 am
Sexy Fuel, that. Mine has nearly perfect skins, so it gets babied.
strong_epoxy
Re: Hello again
Unread postby strong_epoxy » Mon Nov 09, 2015 4:39 pm
What kind of camera/lens are you using?
:Cube: :Octane: :Octane2: :O2: :1600SW: :Indigo2IMP: :Indigo: :Indy: :320: :1600SW: :Fuel: :Onyx2:
