Exporting display CDE
Unread postby uunix » Fri Oct 09, 2015 2:26 pm
So, telneted FROM AIX machine to my o2 running 6.5
exported DISPLAY to aix machine
Ran toolchest ok,
Ran ICON CATALOG ok
Ran Media Recorder & VIDEOIN & received:
O2Workstation 2# toolchest &
[1] 1261
O2Workstation 3# Warning: Color name "SGIDarkGray" is not defined
Xlib:  extension "GLX" missing on display "192.168.1.7:0.0".
Warning: Cannot convert string "-*-screen-medium-r-normal--15-*-*-*-*-*-iso8859t
Error: GLwMDrawingArea: requested visual not supported
No matching visual on display `192.168.1.7:0.0'
Can I do anything about this?
Re: Exporting display CDE
Unread postby vishnu » Fri Oct 09, 2015 6:00 pm
The GLwMDrawingArea widget is open source, so you can compile that yourself, you should be able to get the GLX extension from IBM, in fact I'm a bit shocked it's not already in there, what version of AIX is it?
Unread postby uunix » Sat Oct 10, 2015 8:27 am
vishnu wrote:The GLwMDrawingArea widget is open source, so you can compile that yourself, you should be able to get the GLX extension from IBM, in fact I'm a bit shocked it's not already in there, what version of AIX is it?
7 and to be honest Vishnu, it's a pretty shite install. It's like some half assed attempt at loonix, I've half a mind to put AIX 5 on it (if I could find the disk in the loft that is).
Unread postby vishnu » Sat Oct 10, 2015 3:50 pm
What does xdpyinfo | grep -i glx say?
Unread postby uunix » Sun Oct 11, 2015 2:33 am
Zilch, nothing, string.Empty..
Unread postby vishnu » Sun Oct 11, 2015 10:38 pm
So yeah, you def gots no glx extension then, sux to be at the whim of IBM but I can't imagine that extension isn't somewhere in the mass volume of installable AIX parts...
