New guy, just bought a Fuel
sornywrx
Unread postby sornywrx » Tue Aug 18, 2015 6:57 am
Hello guys. I just joined the forum and this is my first post. I have wanted an SGI for 15 years, always being intrigued by the design, the architecture, the power of these machines. I bought one back in 2004 or so, an Indy, but I never could get it to display video even with different 13w3 adapters. I ended up selling it breaking even.
I kept checking eBay for SGIs once a year or so, when I'd get "the fever" again. Was determined this time to get one and saw a Fuel on eBay that was bought as surplus. They had tons of pics but had no idea of what the CPU/memory/etc config was. Very thorough description and it shows the error stating that no disk was found so I know it powers on at least. Not hinv to show specs however. So I took a gamble, figured if I could get it cheap it'd be worth it but kept in mind that it might be the slowest CPU, little ram, and probably the V10 graphics. They said there was NO HD and "2 sticks" of memory so who knows.
I ended up getting it for $222. Which I thought was a pretty ok deal, but knowing I'll need to put a HD in, get IRIX installed, and hope nothing is wrong with it. There are other Fuels listed for $500-900 on there now so I'm hoping it was worth the gamble, but then again realize that eBay SGI prices are hugely inflated, especially the Buy It Now prices where someone might want $250 for an Indy with no HD and 'untested'
I'm hoping the SCSI HD I have works with the Fuel... It's a Seagate ST373405LW, which is a U160 10K drive with a 68pin D connector. That was part of my reasoning for buying the Fuel -- I already have a HD that works (I hope?).
Anyways, I'm ecstatic to find that there's an SGI community because there's not a ton of info online about these machines so I was afraid the community would be dead and there'd be no where to chat about SGIs, get help, and share resources.
Re: New guy, just bought a Fuel
Unread postby Trippynet » Tue Aug 18, 2015 7:09 am
Welcome! Looking forward to seeing some pictures of the Fuel, and a hinv once it's up and running.
Note that even a bottom end Fuel is still a nice little system overall, so as long as it works then I think you've picked up a bargain there!
sornywrx
Unread postby sornywrx » Tue Aug 18, 2015 7:18 am
Thanks!
The auction had some good pics but I'm very anxious to get this thing to my house so I can check it out in person, power it up, and get some more pics/info.
It did list the model number as CMN017, which I googled and kept showing results that all reported it was an R14K 600MHz so I'm not sure if CMN017 is a model number that always came with the 600MHz or if the google results are making it look that way. Either way, even if its low end I'm still excited and will be happy with the performance as I was originally looking at spending this much on an Indy or one of the slower O2s if I was lucky.
Edit: checked out the CMN017 model some more and apparently (I didn't know this) its not specific for a certain CPU. Saw lots of CMN017's listed that had the 500, 600, and 700MHz CPUs. So I guess it'll be a total mystery when I get it but that's ok :)
Unread postby foetz » Tue Aug 18, 2015 7:18 am
welcome sornywrx :-)
just fire it up and at the "title screen" hit 5. this sends you to the prom where you can run "hinv". the output should be a nice overview of what you have so you can see the specs of your machine already
sornywrx
Unread postby sornywrx » Tue Aug 18, 2015 7:21 am
foetz wrote:welcome sornywrx :-)
Cool I didn't know that's how you got to where you can run hinv. I knew what hinv did but didn't know how to get there. Unfortunately the machine hasn't arrived yet. I bought it and paid yesterday and it's only 2 states away so I'm HOPING it shows up this week if they ship it soon.
I just couldn't wait to join the forum and also needed to research and see if my SCSI HD will work with the Fuel.
Unread postby jan-jaap » Tue Aug 18, 2015 8:02 am
sornywrx wrote:I just couldn't wait to join the forum and also needed to research and see if my SCSI HD will work with the Fuel.
I think that disk will work. But does the system come with the SCSI cable? The cable used in the Fuel has an unusual connector on the mainboard side.
sornywrx
Unread postby sornywrx » Tue Aug 18, 2015 8:06 am
I'm not 100% sure but I'm hopeful it does. The same looks to be there in the pics so unless they pulled it it should be there. I had read that the cable is odd and expensive so I'm hoping it's in there. I've got a regular ol' 68 pin SCSI cable from the server this drive came out of but it sounds like I better get one with the Fuel.
Unread postby ClassicHasClass » Tue Aug 18, 2015 10:25 am
Welcome. I love the Indy for nostalgic reasons, but my "super Fuel" is the SGI I use the most, is more friendly to mainstream hardware and monitors, and definitely lends itself to upgrades. If it didn't have some residual value as a workstation, which as you noticed tends to drive prices up, it would be a great starter SGI.
sornywrx
Unread postby sornywrx » Tue Aug 18, 2015 11:10 am
ClassicHasClass wrote:Welcome. I love the Indy for nostalgic reasons, but my "super Fuel" is the SGI I use the most, is more friendly to mainstream hardware and monitors, and definitely lends itself to upgrades. If it didn't have some residual value as a workstation, which as you noticed tends to drive prices up, it would be a great starter SGI.
I was really looking at Indys but since I came across this Fuel for a decent price, not much more than an Indy, I had to have it. To be honest I'm not going to be doing any kind of 3D modeling/rendering so using this as a UNIX workstation will be a fun experience.
I've been a Windows guy (professionally) for 15 years and am currently a Windows/VMware systems engineer who works with a bunch of UNIX admins so it'd be cool to learn some basics past what linux experience i have from playing on my Raspberry Pi.
ajw99uk
Unread postby ajw99uk » Wed Aug 19, 2015 4:39 am
I'd be 99% confident about the drive, given that my Fuel came with a 73GB Seagate inside, and a 146GB version of the model you have has been fine as well.
Can you post a link to the auction page - we might be able to glean some useful hints on spec etc from the pics while you wait for the real thing.
As you've found, CMN017 just means "it's a Fuel" - Octanes and earlier had longer model numbers showing CPU type and speed (e.g. "ANF195" was R10K at 195MHz) so once you can check the label on the back you may find a suffix that shows at least what CPU was inside when it left SGI, before you get to hinv.
Welcome to the forum, btw!
sornywrx
Unread postby sornywrx » Wed Aug 19, 2015 6:22 am
Sure, here's the auction page:
http://www.ebay.com/itm/381354636898
I may be wrong but I'm thinking V10 graphics judging by the ports on the back. They list the serial number but I couldn't find anything that might exist that'd decode it and show stock specs, if even possible.
I was REALLY hoping this thing would have shipped by now so I could get it this week. Patience isn't one of my virtues, especially when I've bought something. The auction clearly states up to a 4 day handling period so I can't complain but I wish they had shipped it by now so I could get it by Friday (I'm in Tennessee, they're in Ohio). Was really hoping to get it in by the weekend so I'd have some time to play with it but I'm just glad I won the auction. I figured someone would outbid me at the last minute -- which they tried but I outbid them with 2 seconds left and won it at $222. Hope I didn't overpay.
Unread postby uunix » Wed Aug 19, 2015 7:54 am
I posted a very large box of Software from little old England to Ohio and it took less than 2 days...
This obviously doesn't help, nor does it make you feel any better.. but thought it worthy to note.
Welcome to the board btw.
sornywrx
Unread postby sornywrx » Wed Aug 19, 2015 8:15 am
Thanks for the welcome, haha, I think once it gets rolling it'll be here quick. It's just that this place is pretty slow to package and ship. Should be a 2 day trip via FedEx Ground if they'll ever get the thing out the door.
I've got a spot cleared on my desk ready to go!
I can use USB KB and mouse on the Fuel, right?
Unread postby Trippynet » Wed Aug 19, 2015 9:54 am
Really hope they pack it well. It looks in very nice cosmetic condition. Even the front flap is intact!
sornywrx
Unread postby sornywrx » Wed Aug 19, 2015 10:39 am
Trippynet wrote:Really hope they pack it well. It looks in very nice cosmetic condition. Even the front flap is intact!
I was very excited that they took such good pics and that it's in good cosmetic condition. I saw so many SGIs on eBay that were beat to hell and were missing doors or had broken plastic.
I read reviews before I even bid and their feedback record makes me optimistic that they're going to pack it well.
