issue with 3 netboards on Impact
kjaer
Re: issue with 3 netboards on Impact
Unread postby kjaer » Thu Mar 05, 2015 11:19 am
change /etc/nsswitch.conf so hosts: has files first, before anything else, and make sure the local hostname and IP appear in /etc/hosts. then fix /etc/resolv.conf to list a name server that you can actually communicate with (or remove it if you don't have any name server).
nsswitch.conf is also where you can remove references to NIS.
