MIPSpro C Compiler , what about license ?
Re: MIPSpro C Compiler , what about license ?
Unread postby foetz » Sat Feb 28, 2015 11:46 am
as all real unix variants irix does have its own compiler. you can however get a gcc for irix from nekoware and other sources.
the makefile btw is wrong because using -j and -Ox together makes no sense.
duck
Unread postby duck » Sat Feb 28, 2015 12:55 pm
Alas, SGI is dead and sold. The new owners won't likely dig up the license generator unless you shower them with money.
___(o)=
\____)
Unread postby Raion-Fox » Sat Feb 28, 2015 2:03 pm
Or, you can always try backporting Open64 to IRIX. Its the same compiler, but different. :p
