Newbie intro and O2 questions
pettersson
Unread postby pettersson » Sat Feb 28, 2015 7:49 am
Hi,
I am pettersson and recently one of my teenage dreams came true - I now own a SGI o2 (r5k, 128mb).
After cleaning it up a bit, I connected it to my Monitor (DELL U2711, manual says it supports SOG). Machine turned on, I can hear the startup sound, but I get no picture, the power led is green. I have to add, currently ther is no Harddisk installed (got the machine from work and I had to remove the hdd). I thought I might get into some kind of bios to check if the machine is still working, even without a HDD.
Is there any basic tutorial about these machines?
regards
pettersson
Re: Newbie intro and O2 questions
Unread postby uunix » Sat Feb 28, 2015 9:02 am
A few things here, on an o2 using the standard svga out, you don't need to worry about Synce On Green. There may be a possibility the Console (in the PROM) output is set to 'd' and 'g' meaning that it will not display anything until it passes diag.
You may need a serial cable.
Unread postby uunix » Sat Feb 28, 2015 9:07 am
I think (without restarting my o2) if you fire it up an type:
5
SETENV console d
Then reboot, you may possibly et something.
Unread postby uunix » Sat Feb 28, 2015 9:10 am
sorry I meant
SETENV console g
or SETENV console=g
Unread postby josehill » Sat Feb 28, 2015 10:03 am
Welcome, pettersson!
uunix's advice might fix the problem, but the problem might also be that the O2 doesn't know what to do with a 2560 x 1440 resolution display. Is there some way to set the display to use a lower resolution or to use a different display? You might try setting your display to run at 1280x1024 @60Hz or even 1024x768 @60Hz, if possible.
SGI has a lot of documentation at its Techpubs site, including anO2 hardware guide.
PS. O2s do output a SOG signal, so while many modern displays will show the O2 desktop, if they are not truly SOG compatible, the display will have a green tint. For what it is worth, I just plugged an R5k O2 into an older, non-SOG Dell display, and I took a screenshot of the supported resolutions. Notice the green tint.
Unread postby uunix » Sat Feb 28, 2015 10:18 am
josehill wrote:Welcome, pettersson!
josehill, where did you get that resolution from? I can't see it in the OP?
Unread postby josehill » Sat Feb 28, 2015 10:23 am
uunix wrote:josehill, where did you get that resolution from? I can't see it in the OP?
I looked up the specs of petterson's display on the Dell website.
Unread postby uunix » Sat Feb 28, 2015 10:26 am
o2s do not worry about SOG, I could plug mine into a microwave and it would work. Any monitor will work. If I'm wrong I will eat humble pie and stand in the corner.
Unread postby guardian452 » Sat Feb 28, 2015 10:30 am
Your screen does not need to be SOG capable because with O2 it will send the H and V sync on the right pins (unlike using a sun 13w3 adapter which is the wrong pinout for SGI).
It does need to be SOG-tolerant. Meaning, if it isn't compatible it will have a green tint. Lots of very cheap and or very expensive monitors will do this. Your typical dell monitor will work fine :D
Unread postby ClassicHasClass » Sat Feb 28, 2015 10:31 am
I have an active SoG filter on my Indy's video output for this reason.
Unread postby uunix » Sat Feb 28, 2015 10:33 am
What you looked up sounds like the max, I think all monitors will display 1280x1024 etc heck I may be wrong. I've never heard of a monitor that wont go down to required res automatically. BUT.. if the o2 (or any unix machine) is set to a certain display, then that of cause is a different matter.
Unread postby josehill » Sat Feb 28, 2015 10:59 am
uunix wrote:What you looked up sounds like the max, I think all monitors will display 1280x1024 etc heck I may be wrong. I've never heard of a monitor that wont go down to required res automatically. BUT.. if the o2 (or any unix machine) is set to a certain display, then that of cause is a different matter.
Yeah, his display supports 1280x1024, which is why I suggested using it directly. However, I've run into the problem several times when an O2 and a modern monitor are unable to come to an automatic agreement on resolution. In some cases, it seems to be a timeout issue, where if agreement isn't reached quickly enough, one or the other gives up. In those cases, I've either had to manually set the monitor to a known-good resolution, or I've had to toggle display modes manually.
smj
Unread postby smj » Sat Feb 28, 2015 4:02 pm
uunix wrote:If I'm wrong I will eat humble pie and stand in the corner.
Waiting for pictures... ;)
pettersson
Unread postby pettersson » Sat Feb 28, 2015 11:06 pm
Good morning guys,
thanks a lot for your help! Setting the console to g did indeed fix the problem. About the Monitor: It auto adjusted to 1280x1024 and scaled the picture to fill the screen from top to bottom with black bars on both sided. Looks quite good :D So I guess it's safe to say the DELL u2711 is compatible.
Now I need to get a compatible HD. I can't wait to play Quake on this little machine :)
Unread postby Trippynet » Sun Mar 01, 2015 3:12 am
Best of luck with it! The O2s aren't the fastest things around, but they are very small, neat and cute. It's also fairly straight-forward to replace the fan in the PSU to make them almost silent in operation as well.
Hard drive wise, any 1" high 80pin SCA drive will do. I'm fortunate in that I've acquired quite a pile of them from old decommissioned servers at work. Hence for a while, my O2 (back when it was in use) had two 300GB 10k hard drives in it. Of course, next step after that is to hope you've got a set of IRIX CDs kicking around :)
