My resolv.conf resets on every boot
MrWeedster
Unread postby MrWeedster » Tue Nov 25, 2014 7:27 am
Greetings.
Setting up my fuel for installing the soon-to-arrive o2 gives me headaches again...
I try to change my network settings so she takes my new router/network as default, but it always resets to the old settings.
New: 192.168.178/24 with Gateway/NS: 192.168.178.1
Old: 192.168.0/24 with Gateway/NS: 192.168.0.254
Domain name is cause of the fritz!box: fritz.box
So i put in hosts
192.168.178.65  fuel.fritz.box  fuel
resolv.conf before boot
domain fritz.box
nameserver 192.168.178.1
resolv.conf after boot
domain
nameserver 192.168.0.254
/etc/config/static-route.options
$ROUTE $QUIET add -net default 192.168.178.1
I enabled dhcp, ran the network config with every user in every possibility to change the network settings in every way, no chance.
On every reboot the same settings in resolv.conf
Why, oh why, oh why?
Re: My resolv.conf resets on every boot
Unread postby jan-jaap » Tue Nov 25, 2014 8:10 am
The old router is still connected and answers the DHCP queries faster than the new one?
It's fairly normal that a DHCP client rewrites the resolv.conf, although I don't have much experience with DHCP on IRIX.
MrWeedster
Unread postby MrWeedster » Tue Nov 25, 2014 8:30 am
Uhm, no, the old router is long gone.
And i also tried running network without dhcp client.
Unread postby foetz » Tue Nov 25, 2014 12:19 pm
never use dhcp unless you need it for some weird reason.
the resolv.conf of 6.5.x doesn't need the domain entry. i'd just leave it out and get the rest sorted in hosts
Unread postby Raion-Fox » Tue Nov 25, 2014 10:53 pm
I would fix this on my BSD boxes by setting the immutable flag, but try this:
Set the resolved.conf the way you want then chmod the file 444 and see if that prevents it being written to.
diegel
Unread postby diegel » Thu Nov 27, 2014 12:13 am
Did you try
chkconfig autoconfig_ipaddress off
