What Firefox/Thunderbird addons are you using?
diegel
Unread postby diegel » Thu Feb 13, 2014 3:14 am
It becomes more and more difficult to find working addons for our old firefox/thunderbird versions. I am planning to add the most common extensions to the nekoware packages. I am using:
firefox: Adblick Plus, German dictionary, NoScript
thunderbird: Mail Redirect, German dictionary
What are you using?
Geoman
Re: What Firefox/Thunderbird addons are you using?
Unread postby Geoman » Thu Feb 13, 2014 3:26 am
This is slightly OT,
I'm using the http://winhelp2002.mvps.org/hosts.htm on IRIX and it really helps making FF3 even more usable.
Unread postby hamei » Thu Feb 13, 2014 3:43 am
diegel wrote:What are you using?
No-Script 2.6.6.8rc1
Chatzilla 0.9.86
Firebug was working but I ditched it. It does work but seems like a huge resource hog
Also have a proxy that blocks out a lot of advertising crap, which helps. Same idea as Geoman :D
Two more items that might be relevant :
gtk 2.13.2
freetype 2.5.2 w/subpixel rendering
also
Plugger 5.1.3, got about half the plugins working as helper apps
libivplug works but not too many people put Inventor files up on the internet
movieplayer plays some movies but not all
java 1.1.1c, not that much Java 1.1 out there
ProductView Express, which does not work but claims it does :(
SQLite Manager 4.8.1.8 also works - but I'm not sure I really want to see how much data is being collected by Big Brother back in MinMoz ... people might want to try it, tho. It's interesting.
yetanother**ixuser
Unread postby yetanother**ixuser » Thu Feb 13, 2014 7:11 am
NoScript
Ghostery
HTTPS Everywhere
Adblock Edge
no plan
Unread postby recondas » Thu Feb 13, 2014 9:44 am
Info on versions that work with FF 3.0.19 here: viewtopic.php?f=15&t=16727397&start=15#p7357077
ajw99uk
Re: What Firefox/Thunderbird addons are you using? - compatible Noscript
Unread postby ajw99uk » Mon Jan 12, 2015 5:08 am
A minor update for 2015:
Noscript - 2.6.8.29 seems ok but higher versions fail to install, so beware the offer to upgrade that appears from time to time.
I've not tested with all higher versions, these certainly fail:
2.6.8.31, 32, 35
2.6.9.5, 10
To install 2.6.8.29 via the "get it" page of www.noscript.net, right click on the link to 2.6.9.10, copy link, paste into the address bar, change version number and hit return. The directory containing the binaries is not accesible to browse but see the changelog for a list of version numbers.
Unread postby ClassicHasClass » Mon Jan 12, 2015 4:57 pm
I use Adblock Edge, which is a little lighterweight, but on TenFourFox -- haven't tried it on SGI Firefox.
Sean4000
Unread postby Sean4000 » Thu Jan 15, 2015 12:09 am
Adblock plus, lightbeam, and firebug here.
Unread postby recondas » Thu Jan 15, 2015 4:11 am
ajw99uk wrote:A minor update for 2015:
Noscript - 2.6.8.29 seems ok but higher versions fail to install, so beware the offer to upgrade that appears from time to time. I've not tested with all higher versions, these certainly fail:
2.6.8.31, 32, 35
2.6.9.5, 10
Interesting, because I'm running one of the NoScript versions you mention, 2.6.9.10, on four separate IRIX systems. NoScript 2.6.9.10 is the most current release as I write this.
All four are running FF 3.0.19 from nekoware.
Anyone else running NoScript under IRIX care to report which version they're running?
ajw99uk
Unread postby ajw99uk » Thu Jan 15, 2015 6:51 am
2.6.8.31, 32, 35
2.6.9.5, 10
Interesting indeed, thanks. FF3.0.19 from Nekoware here too, on Fuel (r16k, 700MHz). This prompted me to try again - it seemed to work if Adblock Plus is already installed but not (prior to that) when there were no other add-ons.
BUT despite no error on restarting FF, there is no sign that NS is active, and the preferences dialogue does nothing (I can tick boxes, but "OK" has no effect to apply the choices). Same result on trying without any other add-ons :(
Unread postby hamei » Thu Jan 15, 2015 6:12 pm
recondas wrote:Anyone else running NoScript under IRIX care to report which version they're running?
2.6.5.8rc3 here ... maybe a newer one would work but I chased it this far up the ladder then quit.
Ghostery 5.4.1 does not : I force-installed it but no dice. And now that I read about ghostery, they seem very much like the classic extortion racket ... "Real nice little store you gots heah. It'd be a shame if anyting was ta happen to it ..."
Speaking of fireflop ... was forced into updating the Windoze version to 28. Now every ten seconds the effing thing is dropping down a *&^$% window "Do you want to install the Flash plugin ?" No, no a thousand times no and if I ever find myself in a dark alley with the worthless little asshole who programmed that, only one of us will be coming out alive. Is there a way to turn that OFF ?
Unread postby ClassicHasClass » Fri Jan 16, 2015 10:29 pm
Do you mean that grey infobar for something like "Allow the Flash plugin to run"? This might work: https://addons.mozilla.org/en-US/firefo ... fications/
Unread postby hamei » Sat Jan 17, 2015 2:29 am
ClassicHasClass wrote:Do you mean that grey infobar for something like "Allow the Flash plugin to run"?
I think it was "Would you like to install a plugins to show the media on this page ?" but yeah. Tried the one you mentioned, it didn't work but an older Flashblock did. This wasn't a problem with earlier fireflops. Thank you very much for the suggestion.
What a piece of shit firefox is. All those little twats squealing like pigs about "security ! security !" and then they make crap like that the default, which you have to go elsewhere to find some obscure "plugin" to turn off. What a bunch of worthless dipshit assholes. The world is ready for a real browser instead of the crap we're being force-fed.
Where is the much-vaunted Open Sores Community when they could do something useful ?
