octane dos XIO error
soviet
Unread postby soviet » Thu Mar 21, 2013 8:17 am
Hi, i have a octane the computer seems to work fine but if i stomp on the floor "its wood floor" on the octane i got a XIO error on the logs and the computer shutdown gracefully.
How can i clean the XIO connectors ? any tips on this kind of problem?.
Re: octane dos XIO error
Unread postby vishnu » Thu Mar 21, 2013 10:27 am
Unread postby recondas » Thu Mar 21, 2013 2:11 pm
While you're in there I'd take a close look at the XIO module latching hardware, and check to make sure the chassis or XIO carrier didn't get tweaked somewhere in a previous life. Unless you are very large (and the floor very weak), if the compression connectors are bad enough to generate connection errors from heavy footsteps it seems plausible you'd also see the occasional XIO error during non-seismic use.
soviet
Unread postby soviet » Sat Apr 30, 2016 6:30 am
This XIO issues where linked to a power supply problem fixed the psu and now they diapered.
