Login screen? simple question
malol
Unread postby malol » Mon May 28, 2012 12:51 pm
Hi,
I have been using Octane2 for many years and now decided to change the login window. I got the login screen like on the following picture. How to change it to login screen with user icons?
malol
Re: Login screen? simple question
Unread postby recondas » Mon May 28, 2012 1:02 pm
malol wrote:I have been using Octane2 for many years and now decided to change the login window. I got the login screen like on the following picture. How to change it to login screen with user icons?
Hello malol, welcome to nekochan.
You didn't mention how you changed the login window, but you might check the configuration state for "noiconlogin". If it's set to on, try changing it to "off""
chkconfig noiconlogin off
malol
Unread postby malol » Mon May 28, 2012 3:29 pm
recondas wrote:Hello malol, welcome to nekochan.
I have not changed anything since I got this machine 8 years ago ;)
I am not a UNIX geek, so I am not aware of all the command magic. I got SGI just for one UNIX only software.
Yesterday I was just curious how to make login screen looking better. Thanks for the hint - I found a website with detailed description of the login settings http://madeira.cc.hokudai.ac.jp/RD/take ... login.html and now I know that I was using xdm login.
malol
PymbleSoftware
Unread postby PymbleSoftware » Mon May 28, 2012 4:15 pm
Someone should fix up the wiki..
http://www.nekochan.net/wiki/Visuallogin
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
