Setting up color xterm (HOWTO)
Unread postby nekonoko » Mon Mar 03, 2003 12:57 pm
This came about from an IRC discussion with vegac; we were looking for a way to use color under vim and came up with the following solution:
Grab the color_xterm termcap file from a Linux box. You can download the one we used here.
As root:
mkdir /usr/share/lib/terminfo/c
cp color_xterm /usr/share/lib/terminfo/c/
cp /usr/freeware/share/vim/vim60/vimrc_example.vim ~/.vimrc
Finally set your TERM environment variable to "color_xterm", and all should be well.
This was tried under aterm; other terminals should also work.
semi-fly
Unread postby semi-fly » Tue Mar 04, 2003 7:45 am
Can the termcap file be used for other applications, like 'ls' color syntax highlighting? I'm stuck at work, otherwise I would start palying with the file. :(
Unread postby nekonoko » Tue Mar 04, 2003 7:49 am
Sure ... though that's possible even with standard 'xterm'. Just add an alias in your shell startup file like this one (color ls is located in fileutils-4.1 GNU file utilities SGI Freeware package):
alias ls '/usr/freeware/bin/ls -C -F --color=auto'
vegac
Unread postby vegac » Tue Mar 04, 2003 10:23 am
or for people using bash, like myself
alias ls="/usr/freeware/bin/ls -C -F --color"
also, you MAY have to add
eval `dircolors`
to your shell startup to get the colors set (not sure about that, I just did it by default because I always have)
