IRIX: desktop icons
porter
IRIX: desktop icons
Unread postby porter » Sun Jun 10, 2007 1:57 am
I've never seen any! I've seen pictures of them but never seen any on my desktop, how does one get them?
I use a remote login using xdm and get a desktop with the "tool chest" window and a single terminal. The machine is a headless Indy running 6.5.22m.
How do I get to see some nice desktop icons?
zizban
Re: IRIX: desktop icons
Unread postby zizban » Sun Jun 10, 2007 9:02 am
Good question. I've never run Irix headless. Probably a setting somewhere.
Unread postby recondas » Sun Jun 10, 2007 9:34 am
chkconfig desktop on?
Unread postby josehill » Sun Jun 10, 2007 9:57 am
In the immortal words of Alexis Cousein:
"See differences between /var/X11/xdm/Xsession.dt and Xsession.remote"
Some good info on the old Usenet threads...
porter
Unread postby porter » Mon Jun 11, 2007 1:54 am
Many thanks, the following worked a treat...
Modify /usr/lib/X11/xdm-config to get xdm to run Xsession rather than Xsession-remote. Xsession should run Xsession.dt if the desktop is enabled for the user logging in.
After changing xdm-config don't forget to 'kill -HUP' the xdm server.
ipaddict
Unread postby ipaddict » Mon Jun 11, 2007 9:02 am
wiki wiki wiki :D
