[S]: Nekosync Tutorial or FAQ?
Ebbi
Unread postby Ebbi » Fri Nov 24, 2006 5:39 am
Hi,
when I search for "nekosync", I get 31 results dealing with it.
To be honest, I'm not fond of reading through all these threads, just to determine that I can use 1 post out of 31 topics.
Is there clear documentation for Nekosync, about the prerequisites and how to get started with?
I've been through the nekosync.conf and I installed Perl, but I still end up with
# ./nekosync
Can't locate Digest/MD5.pm in @INC (@INC contains: /usr/share/lib/perl5/irix-n32/5.00404 /usr/share/lib/perl5 /usr/share/lib/perl5/site_perl/irix-n32 /usr/share/lib/perl5/site_perl /usr/share/lib/perl5/sgi_perl .) at ./nekosync line 31.
BEGIN failed--compilation aborted at ./nekosync line 31.
Thanks for your help.
joerg
Re: [S]: Nekosync Tutorial or FAQ?
Unread postby joerg » Fri Nov 24, 2006 7:52 am
Ebbi wrote:Hi,
# ./nekosync
The perl version which comes with your IRIX OS is too old or better dont have the right cpan modules installed.
So put usr/nekoware/bin or usr/freeware/bin into the front of your $PATH and be sure you have neko_perl or fw_perl installed. Than try again.
regards
Joerg
Ebbi
Unread postby Ebbi » Fri Nov 24, 2006 8:12 am
Thanks a lot, I currently have 6.5.10 and fw_perl from the Freeware-CD which comes with 6.5.10 is installed.
LoWeN
Unread postby LoWeN » Fri Nov 24, 2006 8:39 am
Hello,
You need at least 6.5.21 to use nekoware.
LoWeN
UX powered
Ebbi
Unread postby Ebbi » Fri Nov 24, 2006 9:08 am
LoWeN wrote:You need at least 6.5.21 to use nekoware.
That's right, I know that. :)
I justed wanted to see what happens, if I run this script.
But initially I asked for a tutorial. :wink:
