irix desktop enviroment
gcb
Unread postby gcb » Thu Nov 02, 2006 5:25 pm
what exactly is the irix desktop enviroment.
I used irix mainly by remote shells, now i reinstaled everything in my indy (lightning killed main computer, 5 days to thesis dead-line, holyday so i can`t buy another computer today... all the same history as usual) anyway... instaled 6.5 foundations, rebooted, instaled 6.5.22 using graphical swmgr, rebooted.
at both boots, all i get is a low end login screen (used to have icons and other things in my previous installs) and a console windows (used to have icons, toolchest, etc) on a blue background . leftright click on the desktop shows "log out" (used to have lots of things).
another anomality is that clicking in the swmgr's "available software:" icon, also shows only "log out"
What exactly do i have to install/run? Already checked 4dwm, desktop, etc
chkconfig
Unread postby SAQ » Thu Nov 02, 2006 5:54 pm
Look at your "chkconfig" output. Looks like the graphical login and desktop might be off
gcb
Unread postby gcb » Thu Nov 02, 2006 6:03 pm
What should i be looking for?
        Flag                 State
        autoconfig_ipaddress off
        desktop              on
        esp                  on
        fontserver           off
        fw_apache            off
        gated                off
        ipaliases            on
        mediad               on
        mrouted              off
        named                off
        nds                  off
        network              on
        nostickytmp          off
        nsd                  on
        pmcd                 on
        pmie                 off
        proclaim_relayagent  off
        proclaim_server      off
        proxymngr            off
        quickpage            off
        rarpd                off
        routed               off
        rsvpd                off
        rtmond               on
        rwhod                off
        sar                  off
        savecore             on
        sendmail             on
        sendmail_cf          on
        snetd                on
        soundscheme          on
        sysevent             on
        timed                off
        timeslave            off
        ts                   on
        verbose              on
        videod               off
        vswap                off
        windowsystem         on
        xdm                  on
Unread postby josehill » Thu Nov 02, 2006 8:36 pm
That's a pretty short chkconfig list...makes me think that you didn't get a complete installation...
inst
Unread postby SAQ » Thu Nov 02, 2006 9:08 pm
Bring up a terminal window, run inst and open up your .22 overlays and your 6.5 foundations CDs. Type either "install default" or "install all" and "go" you should get what you need. There should be a "visuallogin" option in the chkconfig list for a fully installed desktop_eoe.
gcb
Unread postby gcb » Thu Nov 02, 2006 9:13 pm
I really don`t know what i did with this install. i just had the indy headless in the basement serving http. had only 6.5 plain with freeware apache.
now i just installed .22 overlays. It did ask for the foundations cds...
but well, i already got latex to run. tomorow i will try vim. if i don't find more problems i can postpone my peecee upgrade a little more.
gcb
Unread postby gcb » Fri Nov 03, 2006 5:39 am
i opened swmgr again with the foundations cds.
the regular install shows 4 conflicts. 2 lacking:
-dps_eoe.sw.dpsfonts
-media_warehouse.sw.viewers
and 2 conflicts per se:
-x_eoe.sw.xdps incompatible with eoe.sw.base
-desktop_base.sw.dso6 incompactible with eoe.sw.base
joerg
Unread postby joerg » Fri Nov 03, 2006 5:50 am
I already have seen the same effect. After a plain installation no desktop stuff and login screen was available. Install the missing 'desktop_eoe.sw' stuff and all goes back to normal conditions.
regards
Joerg
Unread postby SAQ » Fri Nov 03, 2006 8:20 am
gcb wrote:i opened swmgr again with the foundations cds.
Those bits require the updated packages in the overlays. Open your .22 as well and they should go away (provided you have a complete overlay set- I've had Windows mess up tardists several times).
gcb
Unread postby gcb » Fri Nov 03, 2006 8:36 am
tried loading the .23 overlays too. but the dependencies where gone when i put in the "complementary apps nov98"... go figure.
Thanks everyone!
btw, instaling vim7 from the nekoware-mips3 was the easisest thing! ...even for me :) thanks again
Hakimoto
Unread postby Hakimoto » Sat Nov 04, 2006 5:27 am
.23 or .22? Indy's shouldn't be loaded with overlays higher than .22 .
grace, elegance and style.
deBug
Re: irix desktop enviroment
Unread postby deBug » Sat Nov 04, 2006 6:20 pm
gcb wrote:what exactly is the irix desktop enviroment.
Maybe you forgot to install path 5086 before .22 overlay?
That will mess upp things pretty good.
