Quick Apache question for X-Plane
No politics, please.
Shiunbird
Unread postby Shiunbird » Tue Mar 14, 2017 8:49 am
Hey guys,
So I'm now flying the X-Plane 9 on my Quad G5 and enjoying it enormously. However, the live weather feature stopped working because the URL for the service changed:
From http://weather.noaa.gov/pub/data/observ ... atever.txt
To http://tgftp.nws.noaa.gov/data/observat ... atever.txt
If they would have kept the paths the same, I could have just updated my hosts file, but they wouldn't make it easy.
So I tried a few things on Apache (old 2.2, the one built in Mac OS 10.5), and updated my hosts file to try weather.noaa.gov against my own machine.
1. Redirect permanent /pub/data/observations/metar/cycles http://tgftp.nws.noaa.gov/data/observat ... tar/cycles.
Result: X-Plane doesn't understand the redirection and doesn't try the new URL.
2. ProxyRequests On
ProxyPassReverse /pub/data/observations/metar/cycles http://tgftp.nws.noaa.gov/data/observat ... tar/cycles
and
3. ProxyRequests On
ProxyVia On
RewriteEngine On
ReWriteCond %{HTTP_HOST} ^weather\.noaa\.gov$
ReWriteRule /pub(.*)$ http://tgftp.nws.noaa.gov/$1
And I get this (Apache log):
Tue Mar 14 16:14:25 2017] [debug] proxy_util.c(1818): proxy: grabbed scoreboard slot 0 in child 1823 for worker proxy:forward
[Tue Mar 14 16:14:25 2017] [debug] proxy_util.c(1934): proxy: initialized single connection worker 0 in child 1823 for (*)
[Tue Mar 14 16:14:25 2017] [debug] proxy_util.c(1818): proxy: grabbed scoreboard slot 1 in child 1823 for worker proxy:reverse
[Tue Mar 14 16:14:25 2017] [debug] proxy_util.c(1934): proxy: initialized single connection worker 1 in child 1823 for (*)
It is clearly getting somewhere, because X-Plane downloads this from the tgftp.nws.noaa.gov server:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://tgftp.nws.noaa.gov//data/observations/metar/cycles/14Z.TXT">here</a>.</p>
</body></html>
I suspect my regexp re-writing the URL is bad, but I can't find it. Any tips? It has to be something stupid. =)
Thanks a ton!
Edit: This is the access log:
192.168.40.141 - - [14/Mar/2017:16:56:35 +0100] "GET /pub/data/observations/metar/cycles/14Z.TXT HTTP/1.1" 302 248
I'm not sure it shows the request before or after processing, I assume before.
Elf
Re: Quick Apache question for X-Plane
Unread postby Elf » Tue Mar 14, 2017 9:50 pm
I would sort of expect something like:
ProxyRequests On
ProxyPass /pub http://tgftp.nws.noaa.gov/data
ProxyPassReverse /pub http://tgftp.nws.noaa.gov/data
Without any need to use mod_rewrite.
Shiunbird
Unread postby Shiunbird » Wed Mar 15, 2017 9:40 am
Elf wrote:I would sort of expect something like:
ProxyRequests On
This did the trick:
ProxyRequests On
If I kept /data there, it would send over /data/data
Many thanks!!!
Elf
Unread postby Elf » Wed Mar 15, 2017 6:15 pm
Glad you got it working :)
Shiunbird
Unread postby Shiunbird » Thu Mar 16, 2017 12:39 am
I forwarded the tip to some folks at the X-Plane forum.
To get this working they were using an hex editor to edit the executables to change where the program looks for the weather data (it is hard-coded).
Windows folks can't do this, because then anti-hackzors protection won't let you run the file anymore (especially if you got X-Plane from Steam).
Or, some guy created a java package with Apache proxy pre-configured and he sells it for 16 USD.
Return to “Everything Else”
