your latest purchase
No politics, please.
- ClassicHasClass
- Donor
- Contact:
Re: your latest purchase
Got a couple more FireWire hubs since I've junked the FW card in the G4 fileserver. The hub smoothes out a lot of problems with having multiple mass storage FW devices connected.
bigred, 900MHz R16K, 4GB RAM, V12 DCD, 6.5.30
indy, 150MHz R4400SC, 256MB RAM, XL24, 6.5.10
purplehaze, 175MHz R10000, Solid IMPACT
probably posted from
bruce, Quad 2.5GHz PowerPC 970MP, 16GB RAM, Mac OS X 10.4.11
- ClassicHasClass
- Donor
- Contact:
Also, I, uh, invested about $4 and got this.
http://www.floodgap.com/iv/3250
Bustin' makes me feel go-o-od.
- Raion-Fox
- Donor
- Contact:
ClassicHasClass wrote:Got a couple more FireWire hubs since I've junked the FW card in the G4 fileserver. The hub smoothes out a lot of problems with having multiple mass storage FW devices connected.
Firewire really is better than USB. Wonder why Apple gave up on it, and Thunderbolt too effectively.
- guardian452
- Donor
Raion-Fox wrote:ClassicHasClass wrote:Got a couple more FireWire hubs since I've junked the FW card in the G4 fileserver. The hub smoothes out a lot of problems with having multiple mass storage FW devices connected.
Apple was late to the TB3 party but the new macbook pro supports it... How did they give up on thunderbolt, again?
Far as I know the only macbook without thunderbolt is the tiny 12"... maybe coming in a future update? and the air is stuck on TB2, probably till it's discontinued.
Firewire was superior to other technology at the time (better than USB when it was stuck at 11mbps) but it was expensive both in terms of hardware, and energy. It was great for video cameras and ipods with PCs that had late-90's CPU power, but USB2 came out and sort of obsoleted it. It was amazing compared to a serial port. FW800 never really took off, tho I used it on an external disk for many years to my macpro1,1 without issue. It didn't make sense for such rare use cases when they could sell a thunderbolt-firewire adapter.
You have to remember back in those days we had digital cameras with built-in floppy drives (sony mavica), that's what we used at my high school. Firewire was too expensive, and we were so amazed with the digital camera it didn't matter!
- ClassicHasClass
- Donor
- Contact:
Sort of, yes. On paper the 480Mbit speed of USB 2.0 should have blown FW400 away but most mass-storage devices still had better throughput with FW400, sometimes beating USB 2.0 on the same device by as much as 25%. In fairness Apple tended to favour FW at the time over USB for that application, though there was still a delta on Windows.
That said, all I use FW for these days is ... cameras and mass storage. Which is what I was using it for back then too.
- jan-jaap
- Donor
- Contact:
ClassicHasClass wrote:USB2 came out and sort of obsoleted it.
The 480Mbit number for USB2 is raw wire transfer rate, after you deduct 8b/10b encoding you're left with 400Mbit. The 400Mbit number of FW400 is *after* 8b/10b encoding, so effective transfer rates are the same.
IEEE1394 uses SBP2 (SCSI over FireWire) which is much more efficient than whatever USB2 mass storage uses. That's why external disks work better (faster, less CPU load) with FW than USB2.
Recently, USB 3.1 I believe started offering SCSI over USB.
FireWire also had direct access to memory, sparing precious CPU cycles when doing lots of operations over the bus.
I have tons of FireWire devices, and so far I haven't had the need to upgrade.
Shiunbird wrote:FireWire also had direct access to memory, sparing precious CPU cycles when doing lots of operations over the bus.
DMA from an external device? Sounds like a bit of a security risk, unless I'm misunderstanding something.
and a small army of
- Raion-Fox
- Donor
- Contact:
Dodoid wrote:DMA from an external device? Sounds like a bit of a security risk, unless I'm misunderstanding something.
Unless your device has rewritable firmware, I don't see it. On my backup disks I use noexec bits for mounting anyways
I suppose I'm used to USB devices where they're a dime a dozen from China, free viruses included. I suppose FireWire was never that cheap/available to sketchy companies.
and a small army of
- guardian452
- Donor
That said, all I use FW for these days is ... cameras and mass storage. Which is what I was using it for back then too.(Well, sometimes a disc burner.)
480 vs. 400 isn't enough to get out of bed over. FW had DMA... and if the device was expensive enough to include it in the first place it was a world apart from a cheap USB jobbie.
jan-jaap wrote:The 480Mbit number for USB2 is raw wire transfer rate, after you deduct 8b/10b encoding you're left with 400Mbit. The 400Mbit number of FW400 is *after* 8b/10b encoding, so effective transfer rates are the same.
That too... but like I said above 480 vs. 400 isn't worth getting excited about. Going from 11 to 400 (usb-FW) or 400 to 10g (FW-TB) or 10g to 40g (TB to TB3)... that's more interesting.
- Raion-Fox
- Donor
- Contact:
USB's problem to me is multi-fold:
You can't directly connect peers together. PC-PC? You can't. At least, in 2.0 and below.
Uses CPU time like IDE and SATA and unlike SCSI
No daisy chaining support in the protocol itself
Inconsistent speeds
I'd gladly revive FW and make it competitive to USB 3.x and Thunderbolt
And G452, it seems Apple's recently going USB-C.
Inconsistent speeds
Raion-Fox wrote:And G452, it seems Apple's recently going USB-C.
TB3 uses a USB-C port, but carries a PCIe, DisplayPort connection as well as the usual USB and power.
and a small army of
- Raion-Fox
- Donor
- Contact:
Dodoid wrote:TB3 uses a USB-C port, but carries a PCIe, DisplayPort connection as well as the usual USB and power.
Huh, I didn't actually know that.
- guardian452
- Donor
How else are you supposed to plug in that gaming GPU to your laptop and charge it with only one cable? viewtopic.php?f=6&t=16731617#p7398178
USB-PD is new. Before C, the host *always* powered the peripheral. The downside is this means your little charging brick is now "smart" enough to crash and require a power cycle occasionally.
Users browsing this forum: mrthinlysliced and 2 guests
