What pointless thing are you doing right now?
No politics, please.
jimmer
Re: What pointless thing are you doing right now?
Unread postby jimmer » Tue Jun 21, 2016 3:16 am
I'm trying to design/put together a woodworking 'shop' (as the americans call it) in my kitchen coz my flat isn't big enough for a 'shed'. Any good suggestions for converting/modding a simple workmate 301 into a table saw... Current idea is to design some sort of 'drop in' mounting unit into the jaws of the workmate. Which might involve replacing the standard jaws with bespoke ones. And yes, of course part of the fun is trying to do the moderately impossible with very modest means and a 'wrong' location, because after all my woodworking the whole 'workbench' needs to fold away behind my bedroom door and the kitchen has to go back to feeding people sawdust-free food :)
:Fuel: redbox 800Mhz 4Gb V12
duck
Unread postby duck » Tue Jun 21, 2016 5:55 am
Got bored with the old ones and made some new wallpapers
http://duck.at.shangtai.net/files/pegboard/
___(o)=
\____)
Unread postby uunix » Tue Jun 21, 2016 12:34 pm
Watching grown men kick a ball around and falling over like toddlers..
I have though purchased some XLR - RCA cables as I have neglected sound in my conquest of Video editing.. <- ooh Wrong thread! :oops:
Unread postby uunix » Thu Mar 02, 2017 4:54 pm
Listening to the Kinks and not doing what I only have 5 days left to do..
I did spend the evening playing on my new G7000 Videopac with my son this afternoon.. nostalgia is a terrible thing..
jimmer
Unread postby jimmer » Thu Mar 02, 2017 5:02 pm
I'm busy not going to bed, watching Tokyo Ghoul instead.
commodorejohn
Unread postby commodorejohn » Thu Mar 02, 2017 5:03 pm
Writing an SDL rotozoomer with support for per-line rotation/scale/offset parameters so I can do SNES RPG-style tilted-plane map effects without having to dig into OpenGL. Already did a proof-of-concept version in FreeBasic, but it was slow as shit because I didn't make any meaningful attempt to optimize on even the algorithmic level. Hopefully the end result here will be a hell of a lot faster.
Unread postby uunix » Thu Mar 02, 2017 5:07 pm
commodorejohn wrote:Writing an SDL rotozoomer with support for per-line rotation/scale/offset parameters so I can do SNES RPG-style tilted-plane map effects without having to dig into OpenGL. Already did a proof-of-concept version in FreeBasic, but it was slow as shit because I didn't make any meaningful attempt to optimize on even the algorithmic level. Hopefully the end result here will be a hell of a lot faster.
I'm unsure how pointless that is commodorejohn, it sounds like you have found a planet we can all live on and is rather fantastic!
Shiunbird
Unread postby Shiunbird » Thu Mar 02, 2017 5:46 pm
It's almost 3am and I can't sleep.
Unread postby Raion-Fox » Thu Mar 02, 2017 6:18 pm
Make sure you add at least 8 sprite layers - and add support for FM sound - some of us prefer FM sound and games from the NES and Genesis (which have fewer colours but more FM sound over the SNES, which I think the cutoff filter and the *only* wavetable generation b-o-ring
commodorejohn
Unread postby commodorejohn » Thu Mar 02, 2017 7:44 pm
Heh :D Layer count will actually be pretty much arbitrary, and sprites are just graphic objects blitted into the layers, so (minus performance considerations) there shouldn't be much of a limit on that. (Heck, you could even have multiple rotozoomer layers - say, a ground map and then a sky map with the same rotation but inverted scaling and a much slower parallax motion. Just need a little fog to hide the sharp-edged horizon and voila, instant skybox.) As for sound, it's still (mostly) in the planning stages, but I'm scheming up a combination subtractive/FM softsynth (plus some kind of wavetable support so at least sampled drums can be used.)
(Also: the SNES sound chip is actually strict wavetable with no proper filter at all, save for the bit that does reverb. What occasionally sounds like a lowpass filter is actually adjustably-weighted linear interpolation between samples, to smooth out the artifacts caused by its built-in sample-compression format.)
Unread postby Raion-Fox » Thu Mar 02, 2017 8:01 pm
commodorejohn wrote:Heh :D Layer count will actually be pretty much arbitrary, and sprites are just graphic objects blitted into the layers, so (minus performance considerations) there shouldn't be much of a limit on that. (Heck, you could even have multiple rotozoomer layers - say, a ground map and then a sky map with the same rotation but inverted scaling and a much slower parallax motion. Just need a little fog to hide the sharp-edged horizon and voila, instant skybox.) As for sound, it's still (mostly) in the planning stages, but I'm scheming up a combination subtractive/FM softsynth (plus some kind of wavetable support so at least sampled drums can be used.)
I see. Unfortunately that explanation re: the SNES sound chip is a little beyond my knowledge of music. All I know is that the way it runs makes things sound muted and stupid compared to how I prefer FM sound - I really like the way later FM systems were capable of switching voices on the fly. I like the YM2612 as well as the 2608 used in the PC 9801-86
commodorejohn
Unread postby commodorejohn » Thu Mar 02, 2017 8:16 pm
The muffled quality to a lot of SNES games has more to do with crappy samples at low sample rates than anything else (I suspect there was a default set in the devkit or something because a lot of games from different developers seem to use the same ones.) In the right hands it can sound quite good (*cough*Chrono Trigger*cough*)
FM avoids that problem because every sound is always synthesized at the same (relatively high) master sample rate and nothing has to be compressed to save memory. (Plus, the technique just naturally lends itself to complex, overtone-rich sounds - Gordon Reid's excellent "Synth Secrets" series for Sound on Sound gives a clear explanation as to why in these three articles.) Of course, FM has its own pitfalls (particularly the "everything sounds like rubber bands and farts" syndrome heard on too many DOS games with token-effort Sound Blaster support,) but so does anything.
Unread postby Raion-Fox » Thu Mar 02, 2017 8:28 pm
commodorejohn wrote:In the right hands it can sound quite good (*cough*Chrono Trigger*cough*)
Oh certainly, I don't for a second discount the wonderful soundtracks on the SNES - but the fact remains that MOTHER 2's tracks carried over from MOTHER on the Famicom sound, brighter and more lively to me I guess.
commodorejohn wrote:) Of course, FM has its own pitfalls (particularly the "everything sounds like rubber bands and farts" syndrome heard on too many DOS games with token-effort Sound Blaster support,) but so does anything.
Most of the DOS games I play are well passed the point of the SB16 - well into the AWE32 era and beyond.
Some soundtracks made in FM I think are stellar are Touhou 4 and 5 on PC-9821, especially the boss tracks for those, and the entirety of Herzog Zwei on the Genesis (I have three copies of the game I love it so much)
Dodoid
Unread postby Dodoid » Sat Mar 04, 2017 4:45 pm
Pointing a cantenna at my friends house and hoping we can connect via Xbee.
and a small army of Image
Unread postby vishnu » Sat Mar 04, 2017 11:24 pm
Dodoid wrote:Pointing a cantenna at my friends house and hoping we can connect via Xbee.
When I was your age we did that with two tin cans and a piece of string... :lol:
Return to “Everything Else”
